I recently upgraded my OS to a 2bar enhanced. I have a 2006 Z06, that has as far as I know, an E38.
I have a big cam, and have had some drivabilty issues, so I thought it would be a good idea to have some VE tables to work from:
I am working on setting up histograms as described in "Calibrated Success", and so far so good. The last histogram I want to build needs a table "Primary VE vs RPM vs Map ", and I can't find it in the table list. I am usure of what to do now.This E38 enhancement contains the following features:
- 2.5 bar (255 kPa) max MAP sensor support (calibration capability for GM 0-5V linear MAP sensors)
- Rescaled MAF High Freq table supports up to 15400 Hz with 300 Hz resolution, also supports airflow up to 1024 g/sec
- New VE tables with 33 x 33 cell resolution each and configurable MAP and RPM axes (choose your own resolution)
- Charge Temperature based VE multiplier table, configurable axis
- TPS based VE multiplier table, 33 x 17 cells with configurable TPS and RPM axes
Please forgive me for asking what I'm sure are elementary questions for some of you that are more experienced. I am trying to make the right steps and move forward with understanding tuning for my car. Any help would be greatly appreciated.
Thanks in advance,
Tony
