This wideband air/fuel gauge also comes standard with a 0 to 5 volt digital output that allows you to connect it to virtually any data logging or engine management system. Free lifetime technical support, one year limited warranty, and full installation instructions come with every Tinted 7 Series Digital Wideband Air/Fuel Ratio Gauge.
NOTE: The included Bosch 4.9 LSU Wideband o2 Sensor includes Bosch’s 30 day manufacturer’s warranty. GlowShift does not warranty this o2 sensor after that 30 day time frame.
Red Digital Wideband A/F Gauge:
2 1/16th Inch (52mm) Black Face with Low Profile Tinted Lens
Red Digital Numeric Display Reads from 10.0 to 20.0 AFR and is Accurate to One Decimal Place
Digital 12 Volt Wideband Contoller Unit with Data Logging Output
Bosch LSU 4.9 Wideband Oxygen Sensor
13 Foot Sensor Wire Harness
6 Foot Control Unit to Gauge Wire Harness
5 Foot Power Wire Harness
Weld-In Sensor Bung
Mounting and Installation Hardware
Free Lifetime Technical Support
One Year Liminted Warranty
Linear Data Logging Outputs:
Linear Narrowband Output: 0 to 1 Volt
Linear Wideband Output: 0 to 5 Volts
