Results 1 to 4 of 4
Thread: AFR' the same in all cells. Why?
    Feb 2010
    16
    Hi,
    My Scanner was working fine and then out of the blue in the AFR Hist. all cells show the same AFR. (12.6) My AEM Wideband is working fine. I haven't changed anything. Any ideas?
    Thank you!
    Jun 2012
    Grand Rapids, MI
    75
    How did you confirm the wideband is working properly? Are you saying that it reads differently in the table than it does in the histo?
    Jack
    -2000 C5
    Nov 2005
    Houston, TX
    3,968
    Sounds like a wiring issue or a problem with the analog output of the AEM. Put a volt meter on it.
    Bill Winters
    Out of the LSx tuning game
    Feb 2010
    16
    I went to check the wiring with a voltmeter and found one of
    Wire had slipped out of the green plug that plugs into the MPVI.
    Reinstalled and problem solved. Thank you for your help!
