damn... lol. guess i better go back to reading.
saw first and thought 1. whoops..
ill change it around and try it tonight after work.
thanks guys.
thanks guys.
1997 s10 4.3-Turbo w/0411 ecu and stuff
2002 s10 2.2-DD ZQ8 clone "TuTu Powa"
And do all three maf to fail on 1st
My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
One trick to help initial light off after clearing codes or flashing is to put a theoretically accurate MAF value across the whole MAF table. Something like 2.8lb/min should work. Otherwise the PCM will reference 0hz which may have .2lb/min.
'20 AT4
'01 Suburban 2500 Dad Wagon
okay, it works a bit better. still have to throttle it some to keep it running to get it to throw the codes, but i can get them to set in 5 or less trys. which is okay with me, continuing to tune the idle might make it better?
already have my old info left in the maf table.
any idea on the case relearn info though? with having other power train codes? last time i tried it i got a too "high of rpm" result.
i really do appreciate the help guys, even with my failure to read.
heres the tune that in the truck now.
probably going to start doing raf tomorrow.
No matter what you do, you're starting off wrong with that Injector data.
been working on the turn for this today,
fixed the injector tables.
logged some info for the raf table.
and adjusted my ve table some.
no boost runs, just trying to get drivabilty better right now to put some miles on it.
still need to do a case relearn.
its been firing right up with the help of some throttling after a reflash.
heres the current tune, i appreciate the help guys!
