Results 1 to 3 of 3
Thread: can someone give me a guide for all of these injector values?!?!?!?
    Jul 2012
    5
    Well heres the story. Starting to tune the car, going from a 32# injector setup to a 103# setup. need to know where to start. i got the charts from the injector manufacturer, but there are so many damn different numbers idk where to begin.
    As far as i know, there are a couple main things that need changed:
    flow rate vs kpa
    flow rate modifier vs Volts
    min injector pulse
    short pulse adder
    offset vs volts vs vac
    and when i get all these setup, how do i make up the difference or the injector size/?
    Dec 2011
    Melbourne, Australia
    82
    Quote Originally Posted by bobsmyuncle View Post
    flow rate vs kpa
    min injector pulse
    short pulse adder
    your best bet is to read the forums, yes it takes forever but in the long run you'll understand what your doing (well better than if someone hands it to you on a plate)
    consider if you have a return/returnless fuel system in your maths
    short pulse is a drop in value off your charts, min injector pulse is a drop in value, flow rate modifier is via your charts, flow rate vs kpa is off your charts, off.v.volts.v.vac is a chart grab as well
    if you don't have the exact values in your charts (e.g. columns don't match) you can interpolate using excel
    hope this gets you started
    stock 99' LS1 + powerglide
    gt42 a/r 1.06
    #80lb siemens @ 43.5psi rail pressure on E85
    return fuel system runing 1:1 FPR
    aeromotive A-1000 pump
    2 bar SD tune
    Dec 2009
    Slave Ship
    199
    Post a tune and the injector data
