I noticed this morning as I was driving that my scanner was continuously at 13.62 for AFR commanded ratio high res and entering PE mode it would drop to 11.5. Commanded EQ ratio (SAE) is still at 1.00 though. A couple days ago while scanning, I was seeing AFR commaned high res at 14.5 and PE mode was dropping to about 12.2, both as desired. The only thing I have changed between these scans is I redone the MAF calibration for low frequency and I changed the MAP kPa PE enable value from 55kPa to 40 kPa. Any ideas?
