P0420 Dtc Can I Change Low Threshold Cat Efficiency
HELLO GENTS
I HAVE A 2000 CAMARO SS WITH A LS1 5.7L ENGINE
I HAVE A DTC THAT IS CAUSED BY THE CATALYTIC CONVERTER EFFICIENCY
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
I WANT TO LOWER THE EFFICIENCY THRESHOLD SO IT DOESN’T TRIP SO EASY
IT WILL RUN FOR A DAY OR SO AND THEN CHECK ENGINE LIGHT COMES ON
I CHANGED MY CATS TO MAGNAFLOWS 2X, ONLY A YEAR OLD NOW
IT SEEMS TO BE JUST ON THE EDGE OF THE THRESHOLD
I READ THAT AFTERMARKET CATS (THESE WERE DIRECT FITS) TEND TO CAUSE PROBLEMS
I MAY GO BACK TO AC DELCO (500.00 EACH)
IS THIS A BAD IDEA, CAUSE IT TO RUN TO RICH OR LEAN
ALSO CAN THE SOFTWARE TELL IF THERE IS ANOTHER BAD SENSOR IN THE SYSTEM
THANKS
