First off, I'd like to say I'm sorry as this is not related to a performance tune that I installed in the vehicle, I'm just using VCM to troubleshoot an issue I'm having and didn't really see a good area to post it... also figured some of you tranny guru's might have some input.
Vehicle is an '01 suburban with a 4L60e. I just recently rebuilt the tranny due to a torrington bearing failure. Tranny ran great after the rebuild for about a week, but now it won't shift past 2nd gear... some of the time. That's where it gets tricky, it only has this issue once it's been running and warmed up. I can let it sit for a few hours after driving it and then start it up and it'll shift normal again... then the failure comes back after driving a few miles.
I've got VCM scanner reporting both "Trans Current Gear" and "Trans Shift Mode" for troubleshooting purposes. When everything operates normal, it shows the shift mode as "Normal Shift". After it's shut down and sat for a few minutes, it shows "Normal D2". If driven in this "D2" mode, it will start out in 2nd gear unless I select D1 on the column (this allows a 1-2 shift or 2-1). It will not shift higher than 2nd. If I get it up to about 35 mph and let off the throttle the rpm's roll back down to idle until I push the throttle again, then the rpm's have to spool back up pretty high before it will hook up and it still will not shift. The odd thing is, if I use the VCM controls in this "D2" mode, it will change the gears as I select them. I've tried putting it in "Performance" mode, but it will only go when it's not acting up.
The only DTC that it's throwing related to the tranny is P1810, but it doesn't always show up when it goes into D2 mode. I've considered changing both shift solenoids and the pressure switch manifold but not sure if it'll help or not. My first suggestion was the wife was just going to have to drive it with the laptop hooked up from now on and shift it using VCM scanner... needless to say that didn't go over too well.
From what I understand, the pressure manifold switch tells the ECM what gear is selected based off line pressures. Figured it could have a bad switch showing closed when it shouldn't be. Also figured it could be a solenoid sticking open allowing pressure to be applied when it shouldn't be.
Any suggestions would be greatly appreciatted!!!
Thx,
D
