Results 1 to 8 of 8
Thread: P0300 high load -LS3 with E-Force LS9 cam
    Sep 2006
    Lake of Como - Italy
    219
    hi guys,
    I recently did a 2009 LS3 6L80E, updated with E-Force, LS9 camshaft, LG high flow headers and cat.
    only on heavy load, at high speed (around 200 km/h or more) and heavy throttle, the engine set up a P0300
    any good tip for me?
    I didn't have a log
    thank you
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    what kind of plugs you using?
    check the narrowbands to make sure its an actual misfire.. if plugs are good look for a vacuum leak near the runners..
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Sep 2006
    219
    I tried with both NGK plug, and OEM ZR1 (LS9) Acdelco plug.
    both standard gap and 0.035 gap.
    nothing change,
    can be a little lean on heavy load?
    Mar 2006
    Kuwait
    1,564
    Wink
    Quote Originally Posted by Christian GM View Post
    like WOT at 200kph? How lean is a little?
    I prefer using TR6s on all my builds. N/A and FI
    Bader Norris
    MEP Tuned
    Instagram
    Dec 2009
    12
    We have a 2012 Camaro with an LS3 that has a code p0300 that we can not get rid of. We have already went through the tables and turned off the code but the light still flashes after the vehicle idles for a while. This vehicle also has a healthy cam. Any other ideas?
    Aug 2006
    5BA8
    3,226
    Quote Originally Posted by competitionauto View Post
    Post a tune and a data log. I've done tons of 5th gen Camaros with big cams and never had an issue.
    EFI specialist
    email=[email protected]
    Aug 2006
    5BA8
    3,226
    hi guys,
    I didn't have a log
    thank you
    Chances are, if it's not a real misfire due to load, it's pulling a bunch of timing out, which will cause a misfire under load.
    Data log and tune.........
    EFI specialist
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    First rule of fight club.
    http://www.dsxtuning.com
    Just say no to bull s***.
