Logging a second IAT sensor? 3bar OS
Hey all,
I'm running my stock IAT downstream of my turbo and IC, but would really like to be able to log ambient air temp as well. Is there a way to get another stock IAT sensor logging thru the stock PCM?
Thanks for any input!
Hrmm 5v signal... should be able to drop this straight into HPT then with one of its inputs... right?
The Sensor does not create a 5v Ref the Pcm does.
You could use the AC press switch or EGR pintle position if they are available?
