With a cam this size what should the vacuum be at idle? It seems as though the car is barely pulling any. The map shows 88-90 at idle and when I revv it up it drops down to 35 or so then goes right back up. Im also getting a map failure code (probably due to the very low vacuum at idle) I normally see in the 50s with my old setup. Also the fuel pressure regulator is working like it has no vacuum at all either so I know the map is reading correctly. I have a fast 102mm intake manifold and I had the wrong valley cover bolts on it and one day while tighening it down I heard a pop on the left side..I took it off..put the proper bolts on and very carefully inspected the intake manifold and could not find a single crack or split. I also notice around 2-3k I hear a whistle coming from the engine...any ideas? Im guessing its a pretty bad vacuum leak but I cant seem to find the damn thing.
