Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: 2010 Camaro - 408 cu.in - Procharged F1A
  1. #21
    Jun 2012
    Pirate Ship
    93
    Seems no matter what I do I can't get rid of the surge at idle. Am I just trying to idle this camshaft too low? ( 850 rpms ) I tuned the final airflow min and also adjusted the timing from anywhere from 17 to 21 degrees at idle. Should I try higher like 25
  2. #22
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Nope. Cam should idle at 800 like nothin'
    Always when in doubt perform a Write Entire just to clear up any possible mishaps.
    618/618 motor
    906/862 spray
  3. #23
    Jun 2012
    Pirate Ship
    93
    Quote Originally Posted by IDRIVEAG8GT View Post
    Okay another question how much should the rpm vary when idling?
  4. #24
    Jun 2012
    Pirate Ship
    93
    Ended up with 654 rwhp and and 612 lbs. ft at the rear wheels. Just wondering how the tune looks?
    I had a question about the airflow min and also open/closed loop running. The car is rock solid at idle but when the car is moving the idle hunts up and down (surges). Also if I put the car back in closed loop it seems to run worse at idle. Is there a way to run OL idle say under 1200 rpms and then switch to CL for cruising?
  5. #25
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by Midnite Magic View Post
    No more than 50-60 while watching the tach on the scanner.
    618/618 motor
    906/862 spray
  6. #26
    Aug 2010
    Roswell, N.M.
    1,956
    Try changing the adaptive idle versus VSS settings and see what it does. (Raise/Lower the MPH.)
    618/618 motor
    906/862 spray
