Trying to get this car tuned and would like everyones input on stuff I might be doing wrong.
2010 Camaro L99 - E38 PCM
- 6.0 Liter iron block - 408 cu.in - approx 9.5:1
- Ported LS3 heads
- Speed Inc blower camshaft 235/247 .624 on a 114+4 LSA
- Kooks 1 7/8" headers no cats
- Yank 3200 stall
- FAST 102mm intake & NW 102mm throttle body
- FAST 85 lb. injectors
- Procharger F1A (4.50" pulley)
- ZR1 MAP sensor
- 2 bar SD OS applied
No matter what I do I can't get the car to startup without pedal input. No matter how much I add to the "Airflow Final Min" Once the car is started it is rock solid and will come back down to idle from a blip of the pedal. I have the car in MAF open loop but I would like to get the idle situated before I tune the MAF table. Should I attempt to run the car blended with MAF & SD or just fail the MAF and do a complete SD tune? If so where is a good place to start with a VE table?
Also what is the correct way to deal with the P0300 (random cylinder misfire) at idle? This car has the knock sensors right near a boss on the block near the cylinder head rail very close to the headers so I am sure it is false P0300 at idle. Should I be adjusting the Knock Sensor Level -> Initial Level ? How about the table for misfire under the Engine diagnostic?
I also had a question about all the Open Loop Gains table? Adjust them all to 1.000 or leave them stock?
