Results 1 to 5 of 5
Thread: E67 Airflow/Boost Limits - CTS-V??
    Oct 2009
    9
    I am tuning a CTS-V with a 2.55 upper, 9.0 Lower, intake and it makes about 17psi and it seems that no matter what I am hitting a brick wall around 3900-4100rpm (205-208KPA). I have tried maxing out all airflow tables, boost limit tables based on MAP, temperature, etc.
    Anyone run into this? Unless I am missing a table somewhere as this is the highest boost E67 I have done to date...
    Boost duty cycle goes to 0 when it happens. It is 100 during the beginning of the run
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    You can try this:
    http://www.lingenfelter.com/LPEforum...at-higher-rpms
    But if you have maxed out your boost limits under Torque Management that is probably not it.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    how is ur IAT2 reading ...ran in to same problem before as the inter cooler pump puls water hose was leaking ..lead to very high IAT2 270F ..that will disable the boost ..
    maybe u have something els but that my experience
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
    Aug 2006
    5BA8
    3,253
    What "brick wall"? Does it go into REP? Does it nose over? Is it setting any codes? What do you have your P0068 test set to? Need more info.......
    EFI specialist
    email=[email protected]
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    post your file
    lemme have a look
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
