2010 5.3 turbo dtc's pop up???
Well i was tuning my truck and out of no where i punch the gas, this thing went to engine reduce power engine light and trction control pop up.
Do I'm missing something or im doing something wrong here???
Only mods are 76mm turbo with SD 60 lb's tall, 3600 converter using the 3 lb spring just to tune the part throttle.
I upload the files and the log's, the one named dtc is when i punch it, and theres the pic of the codes.
I would revist the Engine Diagnostics.
Example
max airflow
Airflow delta and Map Delta
@ 79% TP and 4200 Rpm you have 383gs Airflow and a Map of 118Kpa wil exceeds your Max Limits
I would check that when i get my lap top.
So i need to max out
Min ECT
p0068
Enable rpm
Max airflow vs RPM, Max airflow vs IGNV, Airflow Delta, and MAP Delta?
