Results 1 to 4 of 4
Thread: Forced open loop, now traction control dtc?
    Aug 2011
    Alaska
    566
    08 C6Z
    When I failed the MAF for VE tuning yesterday, I got two errors. 1) service electrical system 2) service traction control
    When I put the tune back to normal configuration, I reset the dtc's. Service electrical system is gone, but the traction control error is still in.
    I'm assuming the TC error came in when I failed the MAF, but maybe not? Is this common, and what can I do to clear the error?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Correct, common and is the main reason for the TCS patches under the OS window.
    Aug 2011
    Alaska
    566
    OK, I found the tab and patches. Do you have a write up how to use them somewhere?? The part about "re-write entire OS" has me nervous.
    Aug 2011
    Alaska
    566
    Never mind....
    http://www.hptuners.com/forum/showth...ight=tcs+patch
    I have probably read more than a dozen tuning guides and not one of them mention that TC is disabled when the MAF fails. None mention to use these patches or that you have to re-flash 'entire' when re-enabling the MAF.
