Engine is a lq4,2000 camaro pcm (original was an A4, not reflashed), muncie m20 gearbox, 33lbs injectors.
Problem is idle an neutral revs fine , but on load ( in gear) if do wot it dies, the only codes is evaporative system and transmission codes ,
Question is , if i get trans codes it enters on safe mode or similar ? Do i have to reflash pcm to an m6 tune?
