Results 1 to 19 of 19
Thread: Turbo LS2 boost VE/spark
    Jun 2011
    28
    Hey guys,
    I just wanted to see what any of you would recommend anything to help me solve a problem ive been having. Basically the car falls on its face in boost. Ive got the Primary VE table nailed, but as soon as the car hits boost it stops pulling and gets really choppy. I just feel like theres something im missing that would fix the problem totally. Can anyone tell me whats going on?
    Stock ls2
    walbro 255
    siemens 60#
    holset hx55
    93 octane
    2006 GTO
    1 of 104
    -6 speed
    -Quicksilver Metallic/Red Interior
    -355/365 Stock
    -"Extensive" Intake and Exhaust Work
    -TSW Thruxtons----B&M Short Throw----Pedders Drag Springs----Pedders Front Springs----Pedders Tire Rub Package----Stoptech Drilled & Slotted Rotors----Stoptech Pads----W-T Air Splitter
    Build Thread: http://www.ls1gto.com/forums/showthread.php?t=412715
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,862
    I can't see your tune right now, but are you using he enhanced operating system? Do you have a 2 or 2.5 bar map sensor?
    http://www.dsxtuning.com
    Just say no to bull s***.
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    he is on 2bar OS
    and his Offsets for 2 bar
    1st thing i spotted ,, his VE TABLE ,, his LAST cullom in VE doesnt match his 1st collom in Ve boost
    secondly by comparing his VE table with STOCK GTO 2006 M6
    his VE table is Less then STOCK Ve table
    thirdly ,running in OPEN lope and disabling the LTFT
    4th .. raping the PE ,, and its kind of in the middle of 12.0 to 12.01
    his boost power enrich is 11.5
    he having touched the Trq manegment
    hope you can comment now Dsteck :d
    and if i placed an order for ID or Mapsensors ,, how long does it take to get them ready for ship ?
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Jun 2011
    28
    im using the 2 bar operating system. Im using the beta as well.
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Jun 2011
    28
    Quote Originally Posted by vette_c6 View Post
    he is on 2bar OS
    Thanks for the quick summery....haha
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Mar 2008
    St. Louis, MO
    4,862
    vette_c6: PM me.
    rextheracer: Do you have an actual 2 bar map sensor?
    Jun 2011
    28
    vette_c6: PM me.
    Yes I do
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Jun 2011
    28
    Ive been thinking about re-doing the boost VE table with no PE or BE...i think thats where most of the problems are coming from. So, square one would be:
    -taking the 105 column in primary VE
    -copying it to the 105 column and the last column in boost VE
    -multiplying the last column by 25%
    -disable BE and PE
    -and go from there?
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Jun 2011
    28
    bump
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Mar 2008
    St. Louis, MO
    4,862
    I would heavily advise against that.
    If I get home at a reasonable hour tonight, I will review your stuff and try to help you.
    Jun 2011
    28
    bump
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Dec 2009
    Slave Ship
    199
    What's your base fuel pressure?
    Set your Dynamic Airflow High RPM Disable up above your rev limit if you're running in Speed Density.
    Jun 2011
    28
    Well i dont know the exact number for fuel pressure, but ive got a walbro 255 in the tank and siemens 60lb injectors...that all thats done to the fuel system
    I jacked up the dynamic airflow disable to 7000, car runs a little better but it still stops pulling... (it is a sd tune)
    I found a small leak in my bov, but i dont think that it is the cause of the problem im having...
    do you guys think the spark table and injector data looks normal?
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Dec 2009
    Slave Ship
    199
    Quote Originally Posted by rextheracer View Post
    do you guys think the injector data looks normal?
    No. If you're not using a vacuum referenced regulator you're IFR shouldn't be the same number across the board.
    And you're data is all wrong.
    Jun 2011
    28
    Quote Originally Posted by Nodnarb View Post
    Ok that makes sense, but how is the data all wrong?
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Dec 2009
    Slave Ship
    199
    For one thing, those 60 lb injectors flow more like 70 lb/min at the factory fuel pressure of 4 bar.
    Jun 2011
    28
    I realize that, but since theres a limiting factor of 63.5 or something like that in the flow rate I cant put in the real values...I personally think that changing the stoich value is going to open up a door full of other problems....
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
    Dec 2009
    Slave Ship
    199
    You'll find this quite useful.
    http://www.injectordynamics.com/SteckScale.pdf
    Jun 2011
    28
    Quick question....in the injector settings should I be using the map offset as opposed to the vac offset?
    2006 GTO
    1 of 104
    -6 speed
    -355/365 Stock
