I own a 2010 Camaro LS3 Manual, and have a 2012 LS3 Vette Auto for the weekend.
I compared the 2012 Vette LS3 tune to the 2010 Camaro LS3 and found a few expected differences however it looks like the two main areas that I would expect to be the same, are different (Main spark table, and knock sensor threshold multipliers):
1) On the 2012 LS3 Vette they lowered some values in the knock sensor threshold in a few moderate rpm/load area's on cyl 1-7, #8 is the same as the 2010 Camaro LS3, this would make the Vette pull timing sooner than the 2010 Camaro LS3? (or would it be less sensitive?)
2) Main Spark timing in the 1000-6000rpm, 0.2-0.4 g/sec are quite a bit higher on the 2012 Vette tune than the 2010 Camaro tune. WOT at the higher RPM's seems to be the same.
Pic attached. Do you think these changes would be good for a camaro? At minimum, wouldn't you expect the knock sensor values to be "updated" and a better choice?
BTW.. I have access to few other PRODUTION 2012 GM V8 tunes.. I'll start uploading them.. BTW... The VETTE is the only car I've read that DOES NOT throw a fit when reading entire tune. NOT. ONE. PROBLEM. The 2012 Escalade, 2010 Camaro both mess up BAD and either have to clear codes to get thing to RUN AGAIN, or have to put up with random SES lights, COMPASS errors, or other HIGH COLLANT TEMP AC ERROR... or none of the promised features work!!!!!!!!!!!!!!!!!!!!!! The VETTE LS3 you cant even tell it's been read/scanned.. so there you go. There is a difference between PLATFORMS.
Pic attached:
