Results 1 to 10 of 10
Thread: 2007 Z06 2bar Tune Timing
    Dec 2006
    Fort Lauderdale
    171
    2007 Z06 2bar Tune
    Edit - solved timing issue but now when i get into boost it only reads up to 106kpa in the histogram, not sure if something is off? Why wont it read any higher?
    map is p/n 12591290
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    any reason why you are trying to command a 24:1 air fuel ratio?
    You also have the map sensor set as a 1 bar map sensor so there are two issues right off the bat, I can't imagine what other is out of wack
    HP Tuners Support
    (foff667)
    28,265
    You should set all 3 VE tables to the same value.
    HP Tuners Support
    (foff667)
    28,265
    maf tables really need to have some valid info, stock maf tables would be a good starting point. Even if you set the maf fail freq to 0 we recommend putting the stock maf tables in there rather than leaving them blank.
    Dec 2006
    Fort Lauderdale
    171
    Where do I have it ser as a 1 bar map? Where would I change this? Sorry, used to the gen 3 cars and this should work as is as far as I know
    Dec 2006
    Fort Lauderdale
    171
    I'm also having a hard time determining if the map is in fact a 2bar map
    The scale is set high to trick the vcm for the 85# injectors
    2001 Z06 - Blown (Sold )
    Dec 2006
    Fort Lauderdale
    171
    I tested the voltage on this map and it appears it must be a 1.5bar map because car off ignition on, the voltage reads 3.9v.
    How do I set the map max value ???
    HP Tuners Support
    (foff667)
    28,265
    under the engine diag tab
    Dec 2008
    on the Dyno
    1,825
    No offense but a fragile LS7 with boost isn't the setup to be figuring this kind of stuff out on. Your window of error is very small with them.
    Located in Central Kentucky
    ShorTuning
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    with all respect
    take your car for a tuner ,, or you will break the engine very fast
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
