Results 1 to 8 of 8
Thread: Turbo install ready to tune!!!
    Jun 2010
    559
    We finish installling a turbo to a 2010 silverado, Its a 76mm on a stock 5.3
    Heres my file want to be sure if its on pure MAF, just waiting on the injectors and the scanner that i did with the file stb1 n 2 are way off.
    Jun 2010
    559
    I dont get why my stb1 and 2 are still on...
    5BA8
    3,408
    It's in MAF mode. You still have fuel trims because your O2 readiness ECT isn't set correctly. Set that to 400 or something unachievable.
    FWIW, I don't like setting things to zero (your dynamic airflow). I'd rather there be something in there, like 200 or something.
    email=[email protected]
    Jun 2010
    559
    O2 readiness ECT its at -40, change it up to 400?
    Heres the update file.
    Jun 2010
    559
    My stb1 and 2 were way off because one of the injectors was not sitting down right, about to log it see what it does still eaiting if my file is good to go...
    Jun 2010
    559
    I upload the file and took off the bank 2 sensor 1 off of my down pipe to install the wideband, now i getting codes that are from the sensor i took off is this normal till i install it back?
    p0050
    p0154
    po155
    5BA8
    3,408
    Quote Originally Posted by 02Ls1 View Post
    p0050
    p0154
    po155
    Set those codes to 'no error reported'. Done.
    Jun 2010
    559
    Thanks...
