"Open Loop EQ Ratio Gas (Gear): This table is used to determine the commanded open loop equivalence ratio when running on gasoline and the transmission is in gear.
Open Loop EQ Ratio Gas (P/N): This table is used to determine the commanded open loop equivalence ratio when running on gasoline and the transmission is in park or neutral."
Both of these tables are set to 10 in the stock tune(and in my current tune). Tuning guides tell you to set these tables to 1.
What will happen to my AFR in WOT and non-WOT open loop if I change these tables from 10 to 1 without changing anything else, i.e. how do they factor in to the PE EQ ratio?
And do these tables factor in differently when in Closed loop than they do when in OLSD?
Tuning with a LC1...
