Results 1 to 20 of 21
Thread: Clutch Position Relearn
    Jun 2005
    16
    I searched the forum to see if there was an update on clutch relearn being added to HPT. Is there any update on this?
    DV
    from memory its already there.
    I count sheep in hex...
    Jun 2005
    16
    It's there but grayed out on 2008 corvette e38. What am I missing?
    DV
    please contact support with a VCM Suite Info file while connected to the vehicle.
    Tuner 4evervette's Avatar
    Jan 2008
    dyno room
    169
    what does it do ...any more information please ?!!
    specialize in: V8 Conversion & Tuning (UAE- DUBAI)
    supercharge installation
    Salah clutches for Nissan, Toyota and GM car
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    I don't think 2008 Corvettes use the variable clutch position switch. That's probably why it is greyed out.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jan 2008
    dyno room
    169
    dave ...any idea what does it do ...?
    Mar 2008
    St. Louis, MO
    4,859
    No idea but new Camaros have the variable pedal sensor.
    Jun 2005
    16
    Some of the later 08's do have the rotary style clutch position sensor. Mine does anyway. I'm wanting to install a Tick Adjustable Clutch Master Cylinder in mine.
    I like your avatar! Just installed a RPS Billet Twin Carbon clutch in mine. I really like it.
    Jun 2005
    16
    Quote Originally Posted by Chris@HPTuners View Post
    Ok. Will do.
    Jun 2005
    16
    Quote Originally Posted by 4evervette View Post
    The later models have a rotary switch to tell the ecm where the clutch pedal is. Earlier models just have switches. One at the top (cruise disengage) and one at the bottom. (nuetral safety/engine startup). If you change your pedal travel, let's say you put a Tick adjustable clutch master cylinder then a "clutch pos relearn is needed.
    DV
    it tells the ECM where the bottom of travel point is.
    BTW, i think i have fixed this in the newest beta 2.23.602 or later
    Jun 2005
    16
    Thanks Chris. I'll shoot bill an email and get the latest beta. I currently have 2.23.546.
    DV
    Jun 2005
    16
    I got the latest beta. Clutch Ped Learn is no longer grayed out. However it is non functional. Click button and nothing happens. FYI
    Thanks,
    DV
    you hold the clutch fully depressed (or where you want the max position to be) then click the button
    Jun 2005
    16
    Ok. Thanks. I'll try it again.
    Thanks,
    DV
    Jan 2008
    dyno room
    169
    Does the car need to be running or only key on ?!
    Jun 2005
    16
    I don't know. I tried it with it running and it doesn't do anything. I'll try it tommorrow with key on and see.
    DV
    key on, engine not running.
    Ok i added some new PIDs in the scanner so you can see the Clutch Learn Status and the Clutch In Learned Position and the Clutch Out Learned Position.
    You'll need version 2.23.620 or later to see them.
    The 6 states of the Clutch In Learn Status are:
    - Disabled (learning is diabled)
    - In Progress (learning is active)
    - Pass (learn suceeeded)
    - Fail Low (learn failed due to pedal position being below learn low limit)
    - Fail High (learn failed due to pedal position being above learn high limit)
    - Fail Moving (learn failed due to pedal position not being steady enough)
    Jan 2011
    5
    From the grave, could someone tell me where the location of the relearn button is? Also, does anyone know how high it will allow it to learn? IE will it learn in a clutch stop set very high for a RPS triple disc which engages high?
    Edit; it's in the scanner, and yes it will learn a very high position as 100% disengaged. Works great.
    2010 Corvette grand sport Manual.
