So here is a copy of my tune and I need help to figure out why I am not getting my commanded advance timing. The highest I have ever seen is 12.5 at wot top rpm range.
I have made sure that all 4 tables are showing the same timing. I have also checked to make sure that my IAT are sky rocketing up with would cause the computer to pull a few degrees. I am not sure if the right way to go about it is to raise the commanded till I get the actual to be where I want it but I am afraid that when I least expect it the engine will run the commanded and I will knock out of control.
Any suggestions?
