Results 1 to 8 of 8
Thread: Any pyro's with an output...
    Mar 2009
    43
    for datalogging? Something that we could connect to the HPT interface cable?
    I never thought I'd tune a Duramax, until I bought one.
    Mar 2009
    43
    Bump?
    Feb 2007
    33
    Yes, check out the elite series from autometer, data output ports
    Jun 2012
    Southeast Wisconsin
    24
    would you use the gauge to connect to the interface cable going this route?
    Jimmy
    2005 LLY 4x4 3500 DRW 4 door
    AFE 4" Exhaust, AFE Stage II Intake (w/ Bladerunner), HPTUNER software!
    2012 Keystone Raptor - 41ft 18k lbs
    multiple smaller toys/ trailers/ campers
    Feb 2007
    33
    The gauge has a low output wire (orange), this is what I am connecting to the EIO pin 3, then I will configure a custom pid unless I can find one for it.
    Feb 2007
    33
    Update, the output wires for the elite pyro do not work with EIO as I intended. The elite gauge has two wires one to signal low point and one to signal high point that could be use to activate LED or relay. Back to square one...
    Dec 2011
    Melbourne, Australia
    82
    worst case scenario and i do this with my analogue pyro gauge
    video record the laptop and the gauge refer frames
    tedious but it works as a last resort
    stock 99' LS1 + powerglide
    gt42 a/r 1.06
    #80lb siemens @ 43.5psi rail pressure on E85
    return fuel system runing 1:1 FPR
    aeromotive A-1000 pump
    2 bar SD tune
    Jun 2012
    Southeast Wisconsin
    24
    I was informed that this set-up will work with the HPT:
    http://aeroforcetech.com/products_sensors_egt.html
    I sure hope it does because I'm ordering it lol
    Jimmy
