Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Thread: DFCO Not possible with loose converter?
    Mar 2006
    28
    I recently bought a turbo truck and I've been going through the tune to try and increase the MPG since it only gets about 10mpg.
    I've been fighting DFCO and have been having problems with it. I can get DFCO to enable, but it disables after about 2 to 3 seconds because the RPM of the truck is falling below 400 rpm (I have it set to disable at 400) when DFCO enables while cruising between 50 and 60 mph. Is DFCO not possible with a loose converter or could something else be causing the major RPM drop? I'm running a 4L80E with a Precision Industries 3800 stall.
    Any help would be appreciated!
    Mar 2006
    28
    Just an update to original post. I can get DFCO to work above 55~60mph.
    Anything less than 50mph, the truck will actually stall out (I had exit limits very low for testing/scanning). I've now got DFCO exit at 750rpm and the truck will stay in DFCO until about ~50-53mph at which point it hits 750rpm and exits out. I was able to take a freeway this morning and it seems to work pretty good above 60mph. Just wish I could make more use of it for city driving as that is what I do the most of.
    Mar 2011
    348
    if there was a way to hold lockup on decel it would really help
    My setup is a 356ci with a 260/268 (212/218 at .050 lift) duration cam with aluminium corvette heads and flat top pistons running 11.3 comp. ratio. with tuned port injection and vortec crank pick up and dizzy running a 411 pcm and 60lb bosch injectors, 1.6 ratio roller rockers. For transmission its a 4l65e built with the monster in a box mega ss kit. All in a 92 chevy ext cab 4x4 pickup with a 98 cab now installed with a third door! running only e85
    Dec 2008
    on the Dyno
    1,022
    I'm assuming that you did a segment swap for the 80e, that is the reason. They unlock when you let off the throttle. Most of the 60e segments do not unlock when the throttle closes. There are tables for this that we cannot see in hptuners software.
    James Short - James@ShorTuning.com
    Located in Central Kentucky
    ShorTuning
    Jun 2008
    Charleston, SC
    955
    need to figure out a way to keep converter locked. i have a 3600 yank that i can keep locked and can stay in DFCO all the way from 76 to 20 downshifting with the paddles.
    Mar 2011
    348
    Yes I did a segment swap
    HP Tuners Owner Chris@HPTuners's Avatar
    Mar 2003
    Melbourne, Australia
    5,194
    email your tune to support, i'd like to solve this for all 4L80e's
    I count sheep in hex...
    Dec 2008
    on the Dyno
    1,022
    ShorTuning
    Mar 2011
    348
    You talking about the segment swap from a 4l80e to 4l60e. what should i put in the subject line. I'd like to get my mine to hold on throttle lift. Sucks when you cruise at 40mph at 3 percent throttle and any little decline you have the tcc unlock.
    Aug 2006
    5BA8
    1,136
    Quote Originally Posted by Chris@HPTuners View Post
    I'm going to send one in.
    EFI specialist
    Tuning all GMs, Ford, Mopar, Nissan GT-Rs, Evos, WRXs, Euros
    email=edcmat-l1@msn.com
    Mar 2011
    348
    sent my file in. hopefully it can be fixed. it would be nice
    Mar 2003
    5,194
    quick question, when you log TCC Mode and are cruising with TCC in Locked state, what happens when you let off the gas? Does it go directly to Off or something else in between?
    Mar 2003
    5,194
    also someone please post a tune that does not unlock when you let off, preferably OS 12212156
    Mar 2011
    348
    I havent log tcc state but i got the tables set to 99 min and 100 max and as soon as i let off it unlocks and then the sec i push down a little it lock almost right away
    Mar 2003
    5,194
    ok added some new params to the editor for OS 12212156, under Trans TCC section. Requires version 2.23.590 or later.
    Minimum throttle release
    - this sets the TCC to Off when ever the TPS is below the thresholds
    - there are two vehicle speed modes, high speed and low speed
    - for each mode there is a low TPS threshold, if the TPS is below that threshold the TCC will switch to Off if the PCM is not in Coast mode.
    From what ive seen the 4L80e cals do not use the Coast mode, but let me know if this new stuff just doesn't work for you and you see TCC Mode as "Coast" at any time.
    When you set the thresholds it's probably a good idea to make sure the TCC will unlock at low throttle and low speeds, so try to change the VSS modes and high speed thresholds only as a first attempt.
    I have also added a bunch of TCC related status bits to the scanner which will help you see why the TCC is changing to "Off". There are a lot of reasons why the TCC can be set to the Off mode.
    eg.
    - TqMgt or Misfire request Off
    - trans is in 1st gear
    - trans cold
    - brake is on
    - TCC fault
    - slip related
    - min throttle mode (the new params control this)
    - large negative or positive TPS transients
    - Off during upshift or downshift
    etc.
    Mar 2011
    348
    Will scanner status bits work with other OS? attached is my tune
    Mar 2003
    5,194
    new beta up with support for your OS as well in the editor. 2.23.591 or later
    Yes the new PIDs will work for all 99+ LS1's
    Mar 2011
    348
    ty chris
    Dec 2008
    on the Dyno
    1,022
    AWESOME!!!! This will make alot of 80e swapped customers very happy!!
    ShorTuning
    Mar 2003
    5,194
    Please let me know if it works, before we all get too excitied
