Results 1 to 2 of 2
Thread: E39 ECU (another V6 Samurai in the works)
    May 2010
    6
    Just want to confirm whether or not the E39 ECU used in the LF1 and LFX engine is read only right now or will the editor work? If just read only now, is it safe to assume full support will happen soon? Also, does anyone know if the VATS is controlled by the BCM on newer engines or is it still disabled via the editor?
    Planning on doing a V6 swap in my Samurai and would like to use a direct injected engine. Had good luck tuning an LNF and this engine may see forced induction in the future as well.
    Cheers!
    28,298
    Start by emailing support, I can by no means guarantee we'll be adding support for your application but I can at least try.
