I crashed the dyno competition of a neat Mustang event http://www.svtvstheworld.com/ last night at http://autoadrenalineperformance.com/. Nice bunch of guys and they were able to squeeze me in. It did pretty much what I expected. First pull was on 18#, second run I guessed on the EBoost shooting for 20# but only got 19# and it was pretty fat, like low 10:1's. Only had two pulls so had to stop there. No tune changes were made at all. Peak TQ just after 4500 and HP noses over above 6k which I would attribute to the 2.5" downpipes. I would have liked to see 900/900 but it'll just take another pound or two of boost. In any case it was enough to be king of the event.
I'm #6
I found out later that night the I would have had $100 coming to me if there had been enough (three) entries in the turbo class. Oh well.
851/878 on 18#, 879/899 on 19#
Attached are the log of the 19# pull and the tune as well as the config and vcm scanner file. Not sure you will be able to see the AFR/AFR Error without it.
Setup is 408 iron block with 317 heads @ 10.2:1, 231/329 614/621 on 118+2, TTIX base kit w/ 57mm turbos, Alky Control dual nozzle meth, FIC 1k injectors, no cats, Corsa Sports.
