Hey All,
I'm looking for a very choppy idle but when I lower my timing/idle/overspeed settings, exhaust poping after 2400rpm in between shifts. Let me know what you guys think.
P.s Car made 607/533 dyno jet
Thanks.
Hey All,
Thanks.
wow really nobody knows?
Need a bit more specific description. The exhaust pops between shifts? Sounds like DFCO or a lean issue.
08 Panther Black G8 GT, VMR V713's Powder Coated Gray,
Blown, Heads, Cam, Lightened, Forged, Stalled, and is just my DD.
under normal driving anything higher then 1500rpm backfire/minor poping sound. Do you see anything wrong with my file? Should I data log it?
This seems to only happen when car warms up, can I try enable 2500rpm and disable 1200?
Yep you can try that. If it still does it, the problem is clutch fuel cutoff. P.S. I would not leave the rev limit at 7,400 rpm. That's too fast even for LS7 lifters. About 7,200 is max.
I did a shut down log today tps goes from 18% to 28% on it own.
Is there a way to decrease DFCO rate? I'd like to reduce it a bit, if possible. I'm not a big fan of popping every time I lift the throttle. My AFR jumps to 21 when it engages. That seams a bit too aggressive to me.
08 Z06 3LZ
MF 102, Ported intake/TB, AFD ported heads, EPS cam (235/255 113+3 646/670), ARH's, PRT's
Tuning all GMs, Ford, Mopar, Nissan GT-Rs, Evos, WRXs, Euros
email=edcmat-l1@msn.com
I have found most dieseling is caused by wrong injector data. I have a procharged c6z in the shop right now that had 85lb fast injectors which I don't personally have the data for. The car was extremely hard to start and when you shut it off it would keep running for a good 5 seconds. Put a set of stock injectors in it fired the car up nearly like stock and shut off like stock. So with that said getting the fuel shut off when the engine is supposed to shut off is key to keep it from dieseling. The gen4 stuff seems like they are more touchy on that than older gen3 stuff.
I ordered some 80lb Siemens injectors for this car just because I know the data on them and the QC seems much better on them than the junk EV14 FAST injectors. I don't think the particular FAST injectors we had ever actually closed when pressure was on them. They seemed to leak down pretty bad.
2007 Corvette C6 Vert. A6
LME LS402, Pat G custom cam, ATI 10% OD Damper
Circle D triple disc 2600, 3.42 Diff
E force SC, 3.00 pulley, ID 850's
Alky Control Meth,
ARH 1 7/8 headers, cats, xpipe
724 RWHP @ 6500, 866 RWT @ 3700
ZR1 DFCO timing tables cure it...they're even higher. I put in the numbers from the ZR1 and I have literally no popping at all in DFCO.
Whoever said his AFR is going to 21 and that's too agressive...that's just what your wideband maxes at...your AFR is going to just air when you're in DFCO. The injectors turn off. The popping noise is residual fuel blowing up in the pipes because there's not enough spark advance to light it off in the chambers...or it's crappy injectors not closing well...either way, with enough timing, it'll all happen in the chamber and you won't hear the popping.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust.
Ya, I understand what's happening. I just didn't know it was a complete shut off.
I understand the DFCO entry tables, but the exit tables are confusing. Mine (stock tune settings) are all negative from 0 RPM to 3072, then 0's the rest of the way. -10, -10, -10, -8.5, -5.5, -3, -1.5
DFCO entry was +10 across the entire RPM range. I moved these to +18 and there is less popping, but I still have some.
For DFCO exit, do I want to move those numbers to +15 - or so??
08 Z06 3LZ
