Results 1 to 2 of 2
Thread: adjustment for tire size
    Tuner in Training Cinpro's Avatar
    Nov 2007
    West Virginia
    34
    Question adjustment for tire size
    there is a tire size calculator for the J-body cars over at J-body.org that will help you to choose a tire size closest stock for when you choose a plus size rim. how ever I don't think it takes into account if you get a wider rim. for example the stock width is 6", and a 195/75-14 tire, I now have a 7" wide rim with a 225/55-16 tire. my "gas mileage" is off since the change.
    How can I get a more accurate number for the computer to use? I know there are settings in the editor for the speedometer to change things. I was thinking that maybe I could measure the outside diameter of each tire and compute new numbers from there. but what would be the formula for doing that?
    2004 2.2 Ecotec, CompCams Turbo Grind,
    3" exhaust, Precision PTB300-6157 intercooled
    HPT Pro, AEM EUGO wide-band
    Dec 2009
    1,084
    They should be close,
    790 Revs/mile stock compared to 783 Revs/mile new size.
    New size will be .9% slower so speedo would would read 100kph when actually going 100.9 kph
