Hello all, I've been working all winter on 79 jet boat with a Gen III 5.3 running EFI. The guy that modded my harness gave me a MAF tune that needs O2's but I can't run O2's because the exhaust is wet and runs under an engine cover. If I kill water to the exhaust even for a couple of minutes stuff will melt. Also, the exhaust is iron manifold with no provision for O2's.
So I got everything in the other day and fired it up. It idles perfect but stumbles off throttle, cracks and pops to get going, then runs mediocre at best. Well, lets just say other than idle it runs like crap.
I'm going to buy HP tuners tomorrow morning. I found a dealer two towns over that has it in stock. I could post up a copy of the tune that's in it now, but it's totally useless as I'm going to have to ditch the MAF and use the MAP for speed density and keep it in open loop. I have no idea what I'll be looking at on my laptop tomorrow morning, but what can I do to get an initial tune that will work? Gonna have to fine tune by GPS and "seat of the pants" acceleration. Weather shouldn't be too much of an issue here in Texas and jet boats don't really use part throttle much so that part only needs to be close. If I can get a good idle set up, then a good WOT set up, averaging everything in between should be good.
The motor is a 5.3 with a freshened but stock rotating assembly. The heads have been milled to yield a 10:1 compression ratio and correct the smaller base circle on the cam. The heads are also ported. The cam specs are 226/229 .575/.578 on a 112 lsa. Everything, motor, harness, ECM, TAC module and DBW throttle body all came out of a 2002 Tahoe if it matters.
Does anyone have an OLSD tune I can load into this thing, or can I just delete the O2's and MAF and roll with the VE tables that are in it?
EDIT: I can look into this tomorrow. I have the stock truck exhaust manifolds at work. I could mount them upside down and run the exhaust over the transom with O2's to tune....... MAYBE. But it will really screw up the plumbing. This thing has water lines running everywhere. Once the tune is set put the water cooled exhaust back on.
