Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: DOD & Variable Cam, Delete questions
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    Customer brought me a 2010 truck
    No start
    it has DOD and variable cam physicaly deleted via enging built.
    5pin connector is loose at the back of the motor
    no variable buisness to plug into at the timing cover
    ?do the conectors need to be plugged in?
    ?do certain DTCs beed to be left on or turned off?
    Cranks but no start
    -has fuel pressure
    -has spark
    -PCM commands PW at cranking
    -PCM works great in another truck
    -good voltage at the coil harness
    -all fuses check good
    2010 4x4 1500 6.2Liter 9.2:1CR large heads and cam Whipple charger
    Note:
    changing cranking AFR has no effect on cranking
    changing the crancing advance makes it almost want to hit
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    Oct 2008
    297
    yes the dod needs to be turned off and codes for the solenoids set to no error report,, otherwise the pcm automatically goes into 4cyl default mode, if it would start it would only run on 4cyl's,, seen this many times
    vvt cam should also be set to none.
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
    Mar 2006
    sunny So Cal
    292
    Quote Originally Posted by camaro1 View Post
    Got that already
    DOD = Disable
    Camshafts = None
    DTCs disabled:
    P0010
    P0011
    P3400-P03457
    cranks no start
    NotoriouSS TAD
    Oct 2008
    297
    probly need to verify the engine build, crank reluctor and sensor and that the correct 4x cam gear and cover/sensor were used, if you didnt build the engine(who knows what parts are in it)
    Mar 2006
    sunny So Cal
    292
    I have tried:
    -more fuel & less fuel
    -more cranking advance & less advance
    *adding advance almost made it start
    the plugs were visibly wet so backed off off more than a little
    it is not setting any DTCs
    My gut says it has a cam or crank position sensor issue
    here is a datalog of less fuel
    I'm picking up after another tuner has been inside it already.
    So I changed what bugded me in the tune then went into Diag Mode.
    anyone?
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    camaro1
    Digging the sig mods :-)
    BTW
    What does your 2010 A6 make at the wheels?
    yes there could be any number of issues with the build
    from wrong parts to runnout sensor reclutor issues
    the customer is in the know about the motor
    proven local Los Angles builder, I have dynoed the builders motors several times
    I can get all the PNs and info if I press the matter
    Motor is built to non AFM / non DOD / non variable cam.
    the connector for DOD is loose at the back of the motor as it has nothing to plug into
    cant hardly see the Timing over sensor parts
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    original 5.3 VVT cover is not on the motor
    a standard LS2 timing cover was used
    with a normal high perofmance timing set
    ? isnt the VVT 5 wire and the LS2 3 wire CPS connector?
    NotoriouSS TAD
    in teh scanner try logging Fuel CUt Type, ETC Source, ETC TqMgt Type, Spark TqMgt Type, Fuel CUt TqMgt Type
    that will give you an indication if anything weird is happening
    I count sheep in hex...
    Mar 2006
    sunny So Cal
    292
    What I tryed:
    -Set timing for cranking and idle from -30 to +55
    *would kinda fire and idle for a second at +55 degrees
    -set the fuel from stupid rich to studip lean
    *made no measurable difference
    -pulled the injector fuses and tyied to fire it on started fluid
    *it would not fire on starter fluid
    **duplicated the starter fluid test on near identical whipple truck and it ran good like that.
    Next:
    -find top dead center and make a zero timing mark and hit it with a timing light
    ?if there is fuel cut I would have no commanded PW correct?
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    here is it almost starting
    @ 55 degrees timing and low PW
    Put it on jumper cables to my Lt1 caprice that has a high amp alt to ensure good voltage
    NotoriouSS TAD
    Oct 2008
    297
    how about getting back to basics, did you do a compression test and a leak down test
    Mar 2006
    sunny So Cal
    292
    I asked
    Shop owner refused to do a leak down
    the motor is zero miles fresh from his proven builder
    maybe he will change his mind as desperation set in
    NotoriouSS TAD
    Senior Tuner Mep_q8's Avatar
    Mar 2006
    Kuwait
    1,564
    Just for a sec unplug the maf and try switching on the motor. If it works, its sometimes best to start all over again on a fresh new file.
    Bader Norris
    MEP Tuned
    Telephone: +965-55446651
    Email: [email protected]
    Instagram
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Basic test: Does it have spark? Does it have injector pulse?
    Mar 2006
    sunny So Cal
    292
    Quote Originally Posted by Montecarlodrag View Post
    Spark = Yes
    *jumped a TR6 Grounded to the head with the strap open to .060+ gap
    Injector Pulse = Yes
    *commanded PW responds to min inj PW or MAF or Cranking VE
    *noid light jives with commanded PW
    *cranked w/ plug out fuel and air mixure ejects on the exhaust storke
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    Quote Originally Posted by Trailblazin' View Post
    Tryed that..
    Unplugged the MAF
    in MAF mode PW dropps to commanded min. PW as soon as the motor trys to hit...if it trys to hit
    Swtched to VE and then commanded PW jives with cranking VE
    NotoriouSS TAD
    your MAP sensor is reading boost (125kPa) in the log. Maybe that is a problem? Also, you have a lot of ignition timing, 55 deg is a lot!!
    If your getting incorrect map readings it wont start period.
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    www.gforce-tx.com
    [email protected]
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2009 CTS-V 630 RWHP 10.90 @ 129mph
    Mar 2006
    sunny So Cal
    292
    Map values are set to
    linear 312.50
    offset -11.25
    ZR1 Map Part Number = 12592525
    touching boost... I know
    small pullied Whipple pedaling it to fire.
    NotoriouSS TAD
    Mar 2012
    Los Angeles
    62
    id check one cylinder for compression. if none, id pull the timing case cover to check timing.
    maybe someone has a stock hpt file???
