Results 1 to 12 of 12
Thread: Max compression for 93 oct on LS7 with 244/254 .650 cam?
    what is a safe compression ratio for an ls7 with 244/254 .650 lift cam?
    want to ultimately be able to safely run 93 but want more compression for e85
    I'm thinking 12-12.2:1 what does everyone else think?
    Dec 2011
    Clovis, CA
    374
    Nice
    Thanks,
    Dustin
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    12:1 is on the edge for 93 octane but it will work with reasonable timing for a daily driver.
    I wouldn't use 93 with that CR for racing. You will lose all the advantage of the raised CR because you will be forced to use much less timing.
    If you want to use 93 only for a while until you are ready for E85, you'll be ok.
    thank you for the response :-)
    i'm not that up on everything yet, but i'm reading and learning
    I remember reading about how having a larger cam reduces the effective compression ratio.
    IIRC something to do with the valves being open more and longer.
    Nov 2009
    Pegasus Galaxy
    919
    Yes, thats called dynamic compression ratio.
    The static compression ratio is calculated measuring engine's parts and it's always higher than dynamic CR
    The more overlap the cam has, the less dynamic CR
    Ah dynamic yes that's what i was thinking of.
    I couldnt remember if it was static or dynamic that was affected.
    I'll do a search for a dynamic compession calculator for curiosities sake.
    For anyone else wondering about static and dynamic here is a good read
    http://cochise.uia.net/pkelley2/DynamicCR.html
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    for pump gas , i wont hit 12
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Thanks for the feedback everyone
    11.4 is as high as we go on pump gas..
    Now E85 is a different story!
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    www.gforce-tx.com
    [email protected]
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2009 CTS-V 630 RWHP 10.90 @ 129mph
    Jul 2005
    271
    Just built a LS7 for a customer that had 11.9:1 static CR. The cam was very similar to yours, I had the combustion chambers in the factory heads cleaned up and CC'd to 66cc. It runs perfect with no KR activity wot starting at 32 degrees and finishing with timing at 26 degrees all done with crappy Socal 91oct. AFR was from 12.4:1 - 13.0:1 richest at peak torque of 5500 rpm's.
    Remember a big duration cam will scrub off cr in the low rpm range (or become less efficient) while increasing efficiency towards the mid and upper rpm range. Also the engine will ask for quite a bit more timing as well in the ranges where it is most inefficient.
    Quote Originally Posted by HoP View Post
    Great info, thank you for the response!
    That's pretty impressive for socal 91 which is about like EC 89 octane
