what is a safe compression ratio for an ls7 with 244/254 .650 lift cam?
want to ultimately be able to safely run 93 but want more compression for e85
I'm thinking 12-12.2:1 what does everyone else think?
Nice
Thanks,
Dustin
12:1 is on the edge for 93 octane but it will work with reasonable timing for a daily driver.
I wouldn't use 93 with that CR for racing. You will lose all the advantage of the raised CR because you will be forced to use much less timing.
If you want to use 93 only for a while until you are ready for E85, you'll be ok.
thank you for the response :-)
i'm not that up on everything yet, but i'm reading and learning
I remember reading about how having a larger cam reduces the effective compression ratio.
IIRC something to do with the valves being open more and longer.
Yes, thats called dynamic compression ratio.
The static compression ratio is calculated measuring engine's parts and it's always higher than dynamic CR
The more overlap the cam has, the less dynamic CR
Ah dynamic yes that's what i was thinking of.
I couldnt remember if it was static or dynamic that was affected.
I'll do a search for a dynamic compession calculator for curiosities sake.
For anyone else wondering about static and dynamic here is a good read
http://cochise.uia.net/pkelley2/DynamicCR.html
for pump gas , i wont hit 12
specialize in: V8 Tuning (Kuwait)
Abdullah Al-najdi
00965 99369929
www.youtube.com/alnajdi83
Tuners ! Quit Raping your PE TABLE !
instagram : alnajdi83
best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
Thanks for the feedback everyone
11.4 is as high as we go on pump gas..
Now E85 is a different story!
G-FORCE Motorsports
1941 CR 129 Pearland TX 77581
281-993-5451 PH 281-993-5421 FAX
www.gforce-tx.com
[email protected]
PCM Tuner LSX and SCT <-> How Much Force Can You Take??
2009 CTS-V 630 RWHP 10.90 @ 129mph
Just built a LS7 for a customer that had 11.9:1 static CR. The cam was very similar to yours, I had the combustion chambers in the factory heads cleaned up and CC'd to 66cc. It runs perfect with no KR activity wot starting at 32 degrees and finishing with timing at 26 degrees all done with crappy Socal 91oct. AFR was from 12.4:1 - 13.0:1 richest at peak torque of 5500 rpm's.
Remember a big duration cam will scrub off cr in the low rpm range (or become less efficient) while increasing efficiency towards the mid and upper rpm range. Also the engine will ask for quite a bit more timing as well in the ranges where it is most inefficient.
