After a scaled tune in a 2010 GS the transmission shifts very funny, delayed and hanging. I know there has been talks about certain parameters that need to be scaled. Is anything working? Thanks!
Don't scale the long way. Cut the IFR in half and double the stoich AFR.
DSX Tuning - St. Louis, MO
Injector Dynamics dealer/supporter/lemming
Need a plug-and-play 2.5 or 3 bar LS1/2/6/7 MAP sensor? PM me
More importantly, why is he scaling it anyways...jeez
yea, pretty sure unless he is using injectors over 127lbs, no scale is needed
you hit 15,000hz? or the 4000 g/sec? lol
wow... I had to scale the transmission tables anything with torque related pressures and things. Just move accordingly.
1994 Camaro Z28, Custom Painted, Forged 383, 12.5:1, 200 SHOT.
2000 GMC Sierra 4X4, 6.0 LQ9, Ported 317's, ZO6 CAM, All Forged being built!
2005 Ninja ZX10 To the left the day i bought her..
Dustin
How in the hell did you peg the MAF?! Better be making way more than 1,100 horses .
08 Panther Black G8 GT, VMR V713's Powder Coated Gray,
Blown, Heads, Cam, Lightened, Forged, Stalled, and is just my DD.
Look at the log I just posted up. The Maf pegged at 86.69 lb / min. When this happened the car just goes lean. It would not keep the commanded AFR at wot, you can see that by the O2 sensor readings. After scaling it was perfect.
Something to take note of. This is a blown car and the MAF tube is only 3.5" i.d.
You do realize the MAF PID is limited to 86.7 lb/min, but the dynamic airflow will keep going... right? No need to scale a newer car. You can go to the moon on airflow.
Dynamic airflow.
