Results 1 to 6 of 6
Thread: 2005 CTS-V idle hesitation (misfire)
    Apr 2007
    46
    Hi guys , I have 2005 CTSV on the dyno and the car is having something that look like misfire but when Im datalogging misfire I dont have anything , the spark plug and wires are brand new , does somebody has seen this problem before , I do not want to tune the car before finding this problem .
    Jan 2009
    Spokane, WA
    480
    Replace the spark plugs since it started showing signs? or was it before? Replace them again.
    Tuner in Training HO4THSS's Avatar
    Feb 2012
    26
    is this a cammed engine? i had this issue when i first installed my cam, and it was solved after idle tuning.
    Apr 2007
    46
    The wires and plugs were change to solve the problem , beside the exhaust and the removing of converter this car is bone stock
    Apr 2006
    42
    Random misfire or do you have a specific cylinder?
    If you ahve a specific cylinder you need to swap igniton compoenets with another cylinder and see if it follows.
    If it does, igition is a problem. If not, check the usual misfire checks.
    Feb 2012
    26
    post the tune, log and cfg. maybe we will spot something....
