Results 1 to 14 of 14
Thread: AFR for todays Car with ethenol?
    Advanced Tuner Braciole's Avatar
    May 2008
    New Jersey
    227
    Im well aware 12.7-13.0 is the sweet spot for NA LS cars, But is anyone taking into consideration the fact that Ethenol is in almost all gas sold?
    With this in mind is anyone leaving their cars or the cars they tune a little Fatter?
    Thanks for any imput
    2007 C6 coupe LS3 416 6 speed mn Z51 3LT
    Vararam Snake charmer 160 Stat
    Kooks 1 7/8 headers with jet hot
    Fast 102 ported intake 102 TB RPM Level 5 T56
    MGW short throw ZIP 4.10 Severe Duty rear
    RPS TWIN DISC CARBON CLUTCH CCWs ele wp
    RPM LEVEL 5 TRANS W/HARDENED OUTSHAFT
    http://www.youtube.com/watch?v=PtOPy_lp2QY
    10.66 1.47 60ft 133+mph
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    Your wideband is actually logging lambda and calculating AFR... 0.86λ is shown to you as 12.7-ish:1 regardless of ethanol content. That can make it easier to think about. Additionally, as ethanol content rises, the sweet spot for WOT AFR loosens up a shade as well.
    Steve Williams
    TunedbyFrost.com
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by Frost View Post
    Weird. I have the NGK AFX and outside of stoich, I show the AFR/Lambda I'm targeting for my specific fuel
    For instance, I'm targeting .85 Lambda with a 14.13 stoich value for the E10. My wideband outputs ~12 AFR, not ~12.5 as you would suggest.
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    Jan 2006
    Richmond VA
    1,950
    It depends on what the WB manufacturer wants to call stoich though... You can't change what it considers to be stoich with that unit. Some people gripe about that with the AFX.
    Steve Williams
    TunedbyFrost.com
    Feb 2007
    Calgary
    155
    Quote Originally Posted by Gh0st View Post
    Are you sure? I have several AFX's and no matter what fuel, they show around 14.5 in closed loop.
    Jun 2008
    Charleston, SC
    969
    stiotch for afx is 14.56
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by backchannel View Post
    Quote Originally Posted by carlrx7 View Post
    Yep, I'm talking about outside of stoich. Frost said .86 Lambda will show up as 12.7 no matter the ethanol content of the fuel, which is something I don't experience.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I think there's still a lot of confusion on what lambda is and how a wideband really works.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Feb 2007
    Calgary
    155
    My comment was to show that the afx just reads lambda [at stoich or elsewhere] and then converts the display to afr.
    You haven't explained how you are testing to show this is not the case.
    May 2008
    New Jersey
    227
    So nobody is leaving their tunes a little fatter?
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by Braciole View Post
    I run around .85 Lambda, so yes, I am running "fatter".
    Nov 2007
    Minnesota
    555
    I know this, I am not arguing you.
    Feb 2007
    Calgary
    155
    oops - guess I misread
    Mar 2007
    Tucson, Az.
    165
    The actual AFR for regular gasoline at .85 Lambda is indeed approx. 12.5.
    For E10 at .85 Lambda it is indeed approx. 12.0.
