2001 Denali LQ4 drive by wire
I am working on a motor swap, trying to get this thing running.
the 6.0 was originally a drive by wire, we have installed a cabled TB.
I have wired the pins into the PCM for the IAC and TPS
what are the next steps?
thanks for the help
uhmm... Start it? Just sayin...
Thanks,
Dustin
The next step is to check if you have a PCM capable of controlling the IAC for the DBC throttle body.
The only way to know for sure is to open it and look for a specific component. Check this thread for more info:
http://ls1tech.com/forums/conversion...v-hwd-nos.html
Next step is to find the correct stock tune file for your needs and start tuning.
Which car is the engine into?
all 01 pcms are capable of running a cable tb. go into your system/system options and change the 1 under etc to a 0 and you should be good to go.
Im doing the same swap, only mine is a 2002flex fuel 5.3 dbw. I want to go. Dbc. What pins do i need to wire to pcm.. please help..sorry for thread jacking..
