Results 1 to 17 of 17
Thread: FIC reworked stock injectors
    Advanced Tuner domestic rice's Avatar
    Dec 2006
    MB SC
    494
    Guys who have these, what have you had to change in your tune to make them work/run better? Was told injector flow rate was all i needed but wondering if there might be some other tweeks that need to be done to get rid of this low rpm surge.
    99Z A4 w/ SS LT's, h/f cats, magnaflow catback, port/polish t/b, egr deleted, ls6 intake, lid, 3.73's, hpt, performabuilt level 1 tranny, 3600 stall, Stage 2.5 (5.3 heads), Torquer 2 cam, 42# reworked injectors, TR6 plugs.
    2007 Avalanche LTZ - Catback and Eibach springs
    Dec 2011
    Clovis, CA
    374
    From what i understand, getting injector data is like pulling teeth around here. I had no help/response from anyone asking about it. Maybe greg banish can help out here? Or do we gotta "buy" the dvd for all the data @ $250 a pop? still not really sure. Our next set we buy will come with data or we wont buy them.
    Thanks,
    Dustin
    Tuner 1slowbusa's Avatar
    Oct 2010
    Pen Argyl, PA
    102
    I have these http://fuelinjectorconnection.com/sh...&productId=238
    I called up FIC and asked for the flow rate and they gave them to me with no issues. maybe just call them up. I inserted the new flow rates and thats it. But i did have some surging at cold start but did some idle tuning and all that went away. Are you using open or closed loop tuning?
    Jul 2009
    California
    224
    You do not need to buy any DVD to get injector data. All injector is out there free of charge you just gotta look for it. Although I know some so called good tuners that still cant put the correct injector data in tunes for some reason.
    16 psi on E85
    Oct 2008
    297
    fic injector data is the same as injector dynamics, you can get all the data from the id site,, was told this right from fic
    2010 camaro L99, Magnacharger TVS 2300, 415ci LS3,Kooks long tubes, yank ss3200, 3.73 rear
    Dec 2006
    MB SC
    494
    Quote Originally Posted by 1slowbusa View Post
    Running CL. LIke I said all the tune appears to be spot on. The only surge/ problem is at that low rpm/throttle. Just wondering if there was something g injector wise I might have mIssed. I was told since these were the reworked stock ones that the FR would have to be the only thing changed.
    Aug 2006
    5BA8
    3,253
    What are the cam specs? Where is the surging? FWIW, you won't get all of it out. You can't, it's impossible. I can make a bone stock car surge if I get the RPM and load just right.
    EFI specialist
    email=[email protected]
    Dec 2006
    MB SC
    494
    It's a torquer 2. 232/234 with 112lsa. It's only at 1500-2000 rpm's, 35-45 mph, right at 5-6 tps. I asked way back if this Was normal. (never having anytype of built car or even ridden in one I have no clue what is "normal"). I was told it should not surge at all.
    Aug 2006
    5BA8
    3,253
    Quote Originally Posted by domestic rice View Post
    1500-2000 is pretty high, and it should be pretty smooth by then. Most of the surge should be in the 12-1300 rpm range.
    Try turning your fuel trims off while driving. Try using the scanner controls to add and remove timing to see what the engine likes.
    EFI specialist
    Dec 2006
    MB SC
    494
    I did hit disable on the ltft and stft and changed the temp to 285. Problem solved. No surge. Just trying to figure out why it does it only in CL.
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Some setups become really sensitive to the rich lean swing of closed loop. My old cammed NA setup never did it, but my TT baby cammed engine surges from closed loop fueling even though I've cut down the proportional values for CL.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Aug 2006
    5BA8
    3,253
    ^^^This is why.
    EFI specialist
    Senior Tuner Russ K's Avatar
    Dec 2005
    Regina, Sask.
    4,214
    Your camshaft has 9* overlap, so it will have a low rpm/load surge. Raise the TCC lock up above the surging speed. No need to have it lock in 3rd gear on a car. I still lock the TCC in 3rd gear on trucks, or a car that tows a trailer.
    Russ Kemp
    Dec 2006
    MB SC
    494
    I may be wrong but I didnt think I have it locked in 2nd or 3rd. I followed that writeup by coolaid, have the 2nd and 3rd to 255mph. I also have the shift lock disabled.
    Dec 2005
    Regina, Sask.
    4,214
    Try this trans tune. Also disabled the COT, that was the reason the AFR went rich at WOT.
    Russ Kemp
    Dec 2006
    MB SC
    494
    Quote Originally Posted by Russ K View Post
    Russ Kemp
    Thanks for the tweek on the tranny. As for the COT, dont I need that to keep from burning up my cats?
    Dec 2006
    MB SC
    494
    Russ got a P0751 "1-2 shift solenoid valve performance no 1st-4th gear" What would have caused this? I put my old tune back in and it went away, no clue.
    As for injector data on reworked 42lb injectors. Here is what John from FIC sent me. Bunch of good guys there!
