Been working on a single turbo 2010 camaro that has been driving me nuts on the LTFT's. I will admit this is my first SD tune on a newer ECU so I might be missing something obvious. The sensors are post turbo in the downpipe but for some reason they tend to trim themselves in opposite directions. After a couple of min you end up with one bank at a positive percentage and the other at some negative percentage. This only happens at idle. Otherwise I can get the trims set and everything cycling around stoich like it is supposed to and the next time I start the car they are 10-20% off.I know this is partly do to having no injector data but ive never had one vary so much.
