Working on the dfco on my ly6 swapped Sonoma. One part I dont understand is the current settings for the tps enable and disable they seem so low that Id never hit them. It says its a % tps with a range of 0-200 (how do you even get 200% tps?) but my settings are all in the .15/.25-2.0% range. Reading my logs of letting off the gas after a wot run or even cruise the lowest I see the etc is maybe 2% at most on higher rpm letoff but on cruising highway stuff and coasting on a exit ramp its only 5%. Are the settings actually in a direct relation to etc?
