Results 1 to 7 of 7
Thread: 3200stall what tables to modify?
    Nov 2010
    New Mexico
    27
    Of i have a 3200 stall in my 01 camaro and i was woundering ehat all tables would i have to modify and how to modify them? the car seems to jerk/buck a little below 1600rpm not sure if its related to not tuning for the stall but it started right after i installed the stall
    Senior Tuner MMGT1's Avatar
    Feb 2006
    Canada
    1,357
    Dissable torque converter in 3rd gear. Only use it only in 4th and see if it fixes your problem
    2000 Trans Am WS6
    Nov 2010
    New Mexico
    27
    how would i disable it in 3rd? with the apply/release speeds? just make a unrechable speed for that gear? it jerks more in 4th than any other gear but i spend more time in 4th
    Nov 2010
    New Mexico
    27
    why is their no 1st gear in the epply/release speed table?
    Feb 2006
    Canada
    1,357
    Your speed is probably set too low in fourth. Too low an enable speed will cause jerking/bucking. Does not get used in first at all. Yes, set the value to a value it cannot reach to dissable the TC
    2000 Trans Am WS6
    Nov 2010
    New Mexico
    27
    How will disabling the TC effect acceleration? or driveability
    Feb 2006
    Canada
    1,357
    When TC engages too low it causes bucking. Too much load too low in the RPM range. Have it engage at higher RPM and reduce load to clean that up. Do not remove from 4th gear or you will kill it pretty quick. Not having the TC engage will create too much heat and you'll burn the shit out of it man
    2000 Trans Am WS6
