2005 CTS-V, LS6
I just wanted to check if I am setting up the forced open loop calibration correclty to tune the VE table.
I was thinking it was fine until I saw that my commanded AFR in my table display was 14.12, and it gradually got to 14.68 after about 10-15 seconds while idling. The car was over 140 degrees which is where I set my EQ ratio -to start at 1.0
Is there an idle setting I should disable or should I just not worry about it?
Seems my changes in the VE table are helping, I tend to overshoot though. Any ideas on how to help stop this? I am using the Multiply by half % paste function.
Here is my current config and latest scan.
Thanks in advance!
