Results 1 to 12 of 12
Thread: 06 TBSS STOCK w/CAI only
    So after spending a lot of time tuning my other car (WS6), I went and bought a CAI for my bone stock 2WD TBSS. As sad as this sounds, I have no idea where to start for just doing a CAI on the truck. Do I need to go in and tune the VE table and the MAF table? Do I have to do a complete tune like I did with all of the mods on my WS6? I was so use to changing a ton on the car to get it right, that I dont know what to do with something as simple as putting a CAI on my truck... If anyone out there has a good file to at least get me to work in the morning and maybe just get the MAF right it would be a huge help, cause I didn't realize that on this LS2 a CAI would lean it out like it did.
    Thank you for your help
    99' T/A WS6 M6 no emmisions
    Stock bottom end, Edelbrock LT stepped 1 3/4- 1' 7/8, ORY to dump in front of rear axle, LS6 intake, LS6 hand ported heads, LS6 ported Oil pump, Double roller timing chain, Cam 236/242 .601 .610 on 114 lobe, all supporting head mods to support cam, stock rockers, stock lifters, 60# injectors, stock MAF
    Dec 2009
    So MD
    132
    Something is wrong!
    Is there an air leak?
    How much trim are you seeing?
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    TBSS will generally go lean with the addition of a CAI - very common result. Just rework the MAF values, no need to touch the VE.
    Ok so been driving it around now for a little while and got the LTFT looking pretty good on average with the temp at 70ish, but still getting some crazy knock from time to time and it is pulling timing way out to almost -4degrees. Please take a look at this and see if you can figure out what the hell is going on, it will show up just cruising down the road. Whats up with the little hits and some of the real big hits of knock 6Degrees. On WOT im getting no knock at all, just middle and lower RPM's. Attached is the tune and log, was running 2 histos, one with LTFT vs. MAF Low and other vs. MAF high. oh and it looks like my TPS is shot, wont go above 86% or below 25%, any ideas on that too?
    Operating with Beta
    Tuner snowvette's Avatar
    Oct 2008
    Rockford Il.
    135
    Tps is normal, check out the "Read me tuning how tos" stickey at the top of this section.
    Ngk TR6 plugs help.
    2007 Chevy Trailblazer SS AWD with boltons GP tuned
    2012 Chevy Cruze A6 LTZ RS Vermount Stade 0 tuned
    I have not seen any knock till now with adding nothing more then a CAI. What is in the "how to" section gonna do. I don't see any reason I should be seeing 6 degrees of knock in some spots or 1 degree while cruising with no pedal change.
    Nov 2007
    Minnesota
    555
    Fix your MAF calibration.
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    I have been using LTFT's, most are within 2% and where I'm getting knock they are on
    Nov 2007
    Minnesota
    555
    That's not the proper way to calibrate your MAF for WOT fueling.
    Try disabling burst knock retard to see if your knock goes away. Fairly certain you can also log for burst knock to see if that is what is pulling timing.
    I'm not getting knock under wot, I'm getting it else where, I have my WB but don't have and extra bung welded in right now, I know I should use it for wot tuning but for cruising the LTFT should be good.
    Any other ideas?
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Yes lots of ideas. Like overly sensitive knock sensors. Burst Knock Retard being enabled. MAF curve doesn't look right, etc. Tune needs some work.
    618/618 motor
    906/862 spray
