Results 1 to 11 of 11
Thread: Stock truck worth tuning?
    Advanced Tuner domestic rice's Avatar
    Dec 2006
    MB SC
    494
    My 07 Avalanche 5.3 with DOD and cat back only. Is it really worth me taking the time to learn this damm gen 4. The VE tables look like a PITA to do. The 99Z looks very simple compaired to this. And at least with the Z there is a plie of mods so tuning was a must and big hp maker.
    Guys with stock trucks, did you get much for MPG or performance? I am not talking about the neck snaps from jacking up the shift points and psi.
    99Z A4 w/ SS LT's, h/f cats, magnaflow catback, port/polish t/b, egr deleted, ls6 intake, lid, 3.73's, hpt, performabuilt level 1 tranny, 3600 stall, Stage 2.5 (5.3 heads), Torquer 2 cam, 42# reworked injectors, TR6 plugs.
    2007 Avalanche LTZ - Catback and Eibach springs
    Tuner in Training Longslyde's Avatar
    Jan 2012
    St. Cloud, Minnesota
    24
    When I tuned my 2010 in stock form, the difference was VERY noticeable. That was a 6.2L w/6L80E. Gained about 1-2 mpg hyw. I did tune the transmission right away too because of the crappy shift points from the factory. Definitely was more responsive and "felt" like another 20HP from "seat of the pants". YMMV.
    2010 GMC Sierra Crew Cab
    6.2L VVT Flex Fuel
    Whipple Supercharger (11PSI)
    Full Mod 6L80E Trans
    2500 Billet Stall
    Yes, it runs on E85 too and LOVES it!
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,935
    Yep there's a gain to be had.
    08 Panther Black G8 GT, VMR V713's Powder Coated Gray,
    Blown, Heads, Cam, Lightened, Forged, Stalled, and is just my DD.
    Feb 2012
    17
    So when you guys ae tuning a truck what are you adjusting and are you guys using a wb for monitoring?
    Advanced Tuner Asylumwarp's Avatar
    Dec 2011
    Clovis, CA
    228
    Maybe you should just data log it and see if its way off. If so its time for a tune. If not, why spend the credits.. BTW, hows the camaro running?
    Aug 2010
    Roswell, N.M.
    1,935
    All to be touched on is AFR tuning and torque management, which there is tons of. Timing too in some cases.
    Dec 2006
    MB SC
    494
    Quote Originally Posted by Asylumwarp View Post
    I had the credits so thats not an issue. I adjusted the DOD a little so it kicks it from v8 to 4 cyl a little sooner.
    As far as the camaro, its running real good. Still has the light surge from 1500-2000 rpm's. Tried a bunch of things but no dice. Plan on messing with the 02's to come on at 2000 rpms and I think it will be good to go.
    Aug 2010
    Roswell, N.M.
    1,935
    Quote Originally Posted by domestic rice View Post
    Did you time the injectors to the cam?
    Dec 2006
    MB SC
    494
    Quote Originally Posted by IDRIVEAG8GT View Post
    For which one? Ava or Z?
    Aug 2010
    Roswell, N.M.
    1,935
    To the Z. Search Injector boundary timing. Helps a ton with the surge.
    Dec 2011
    Clovis, CA
    228
    Did you also check for timing surge?
    Hey as far as your STFT lean issue, i figured it out. Tune car, then change stoich under fuel, general, to 14.4 from 14.7, that usually fixes STFT lean issues like numbers 4-5 on the lean scale, and its not the switchpoints that does this i found out.
