Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 85
Thread: No start, then start
  1. #61
    Potential Tuner AndyMac's Avatar
    Jun 2011
    Canada!
    8
    Quote Originally Posted by Mike@G-Force View Post
    I had a 07 c6 that was doing this. Classic signs of something funky in the cam sensor/ pick up.
    Pulled the timing cover and bolts were backing out of the cam.
    Had the exact same problem on my 05 C6, random start/no start. A few weeks later it started knocking and threw P0341 IIRC. Cam bolts coming out and wheel was contacting sensor. It was a bone stock car at the time.
    Good luck!
    Andrew MacPherson
    2005 C6 Corvette (HP tuned cam/injectors/exhaust etc)
    2003 Hummer H2 (HP tuned CAI only)
    1995 TT Viper
    2003 Escalade
  2. #62
    Jun 2011
    Canada!
    8
    Also, I hooked up my Snap-On Solus pro scan tool and watched cam and crank counts. The cam count wouldn't change until I reved the car to about 1500rpm.
    Andrew MacPherson
    1995 TT Viper
    2003 Escalade
  3. #63
    Nov 2005
    Houston, TX
    3,968
    The thing is, when it's cranking and not starting I can see the cam sensor counts incrementing. A while back I also measured the distance from the gear to the cover at different points of rotation thinking that the Summit gear was not to spec, and it checked out.
    Thanks for the additional input/experience though.
    Bill Winters
    Out of the LSx tuning game
  4. #64
    Jun 2008
    Charleston, SC
    969
    I finally got a chance to get under the car, forgot to connect the sensor :derp:
    just got done filling the trans, fuk GM for making it so retarded to fill an A6 on a vette.
    -Carl
  5. #65
    Nov 2005
    Houston, TX
    3,968
    OK, haven't messed with this in a while. I just scanned it when it's cranking without starting and I am getting an RPM signal so it's not the crank sensor. Soooooo?
    Bill Winters
  6. #66
    Jun 2009
    Jax FL
    17
    I'd be looking at cam & crank on a labscope. Do you have any access to one? Cam, Crank correlation could be the issue. I've seen this problem with no codes too.
  7. #67
    Nov 2005
    Houston, TX
    3,968
    You mean like an o-scope? I suppose I could wrangle one up somewhere. What would I be looking for exactly?
    Bill Winters
  8. #68
    Oct 2008
    Mebane NC
    475
    You'd be looking for the pulse train coming or lack of from the sensors.
  9. #69
  10. #70
    Nov 2005
    Houston, TX
    3,968
    So since the motor is apart I was able to get a good look at the internals. The cam gear was intact and the reluctor looks straight as an arrow. Could it be that the reluctor is clocked wrong? Ignortant question perhaps, I'm not sure if it even matters the orientation of the reluctor in relation to the crank.
    Bill Winters
  11. #71
    Jun 2008
    Charleston, SC
    969
    Quote Originally Posted by 5_Liter_Eater View Post
    Blame the Tuner or the Engine Builder, one of them fucked up somewhere! lol
  12. #72
    Nov 2005
    Houston, TX
    3,968
    Caaaaaaarrrrrlllllll!
    Bill Winters
  13. #73
    Feb 2006
    South Carolina
    1,525
    Are you running an aftermarket cam gear?
    Jaime
  14. #74
    Nov 2005
    Houston, TX
    3,968
    Yes, it's a double roller from Summit. I do run an iron block so I guess I could take that out of the equation and run the rear cam sensor....or can I? I'd really like to not have this problem when the new motor goes in.
    Bill Winters
  15. #75
    Feb 2006
    South Carolina
    1,525
    The reason I asked is I have had similar problems on a couple of cars over the years and something we discoverd the other day made me think about situations like this.
    The issue was with a transmission output speed sensor. We kept loosing a speed signal and after all attempts at wiring fixes, it was suggested that it maybe the speed sensor is TOO close. Seemed far fetched, but tried shimming it and damn if it didn't work. The best I could figure is that the sensor being that close is still reading the grooves and never really makes a transition from high to low.
    It makes me wonder if the same could be true on the cam sensor. Especially when dealing with a double roller cam gear or one that may have a shallow groove cut. Both cars I've had with this issue were also intermitten but both had double roller LS2 style set-ups and one I know for sure didn't have the issue until after the cam and chain install.
    Just something to think about.
    Jaime
  16. #76
    Nov 2005
    Houston, TX
    3,968
    Good points. Something I may have neglected to mention is that when I first dropped the motor in it was throwing cam sensor codes which ended up being a frayed wire but before I found that I thought it was the cam gear so I took measurements of the cam sensor, cover and gear and filed the cam sensor boss (~.010" IIRC) to get it closer to the gear. The thing is the cam sensor count increments while the car is cranking and doesn't start which makes me think it's fine but it could be a combination of the sensor being too close and the orientation of the cam gear on initial start.
    Quote Originally Posted by ElecTech View Post
    Bill Winters
  17. #77
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    Have you hooked up noid lights to the spark and injectors to see what they're doing when it doesn't start?
    http://www.dsxtuning.com
    Just say no to bull s***.
  18. #78
    Nov 2005
    Houston, TX
    3,968
    Never investigated the injectors but I took a plug wire off and hooked up a plug and grounded it and it was throwing spark while cranking with no start.
    And it smelled of gas when not starting so it definitely seemed like it was getting fuel. Soooo, no clue why gas + spark = no start.
    Bill Winters
  19. #79
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    Just leve the cam sensor out and let the crank sensor take care of it.
  20. #80
    Nov 2005
    Houston, TX
    3,968
    Uh, then it will double start every time and fire in batch mode (if it hasn't been this whole time).
    Bill Winters
