No, not really scaled much at all. 60#'ers.
Bill Winters
Out of the LSx tuning game
Cleaning and verifying the connection of the pins in the connection near the bottom front of the motor is what made the cam sensor codes disappear after I first started up the motor. Haven't come back since then but I think if I let it crank long enough when it's not starting it may. I need to log cam counts and see if it's incrementing when it's exhibiting this behavior.
Bill Winters
I'll try that. I'll admit I haven't worked much on changing the RAF, startup airflow, and other startup tables since I changed setups. They are not optimal. Kind of waiting until after a HPDE in a few weeks and then I'm going to switch to 1k's and start over with a true 50% scaled tune.
Bill Winters
http://www.dsxtuning.com
Just say no to bull s***.
618/618 motor
906/862 spray
I went to a couple of the night meets but not any of the events. Didn't have the car as it wasn't back together then.
Bill Winters
bill,
you better hurry up, the next full moon is on may 6th. lol im dropping my trans/diff again. whats the easiest way you did yours?
warning hijack!
-Carl
- Remove calipers, upper a-arms and lower shock mounts, pop axles out
- Support trans, remove bolts for diff-to-cradle and cradle-to-frame, remove cradle
- Lower trans to be able to get at bolts for TT-bellhousing. Disconnect TT from bellhousing. Start to remove but only enough to get your hand in and remove two 10mm bolts holding the slave to the TT. This is much easier than messing with the slave "quick" disconnect IMO but if you are replacing the slave then you need to do that anyway.
- Remove tt/tranny/diff
- Remove bellhousing
Sounds easy eh? I guess if you're not doing the clutch you could disconnect it at the front of the tranny but I've never done that.
Bill Winters
my DSS carbon shaft has a woble to it, TJ @ rpmtransmissions is going to take a look at it for me. shitty part is my tt was fine.
Pfadt FTW.
Sounds like a bit of a Pain In The Ass. :/
618/618 motor
906/862 spray
yep,, decided to just disconnect the brake line and pull it all at once, much easier.
I fixed the runnout on the driveshaft, just rotated the input shaft on the driveshaft,
but bent my shifterlinkage installing the driveshaft loop over it and torqueing it down. fml
-Carl
Subtle, "I'm a baller with PFADT suspension and carbon driveshaft" post. :P
I'm not sure I follow you on the runout. Sux about the linkage. Think you can bend it back?
Bill Winters
Nice to see I'm not the only one who does my own work. Way to go Carl!
618/618 motor
906/862 spray
I make more in an hour than my installer's labor rate costs me. It's just good business. Lol. It was a different story when I worked for Chrysler for pennies though.
Look at that weak ass base model diff. Pfffft!
needz new rotorz
Bill Winters
618/618 motor
906/862 spray
I'm just saying they look like they have a pretty good lip on them. Thats why he disconnected the brakes because he couldn't get the calipers off.
Bill Winters
