Results 1 to 20 of 27
Thread: FPCM is making my life miserable.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Hey guys, here's another thread that concerns weird things that a GMT900 series pickup does. After the addition of my new fuel system I have been battling my FPCM, and the boost referenced regulator.
    I'm running a twin Walbro 255 in tank fuel pump setup, one fuel pump being powered off the trucks fuel pump circuit, the other connected to a Kenne Bell BAP, which is triggered off of a Hobbs switch set to 3 psi boost.
    Problem is, the regulator is set to 58psi then boost referenced off the manifold.
    The FPCM however only knows low flow, normal, and high flow conditions. So I set normal and low flow to 53psi as that's where it idles at with vacuum on the manifold, and 72psi for high flow as that's 14psi boost.
    Problem is, at mid boost levels the FPCM is commanding 72psi fuel pressure but delivered fuel pressure due to the regulator is only 66psi or so as it will only be boosting 8 psi which trips a CEL of the fuel rail pressure sensor going haywire.
    How in the hell do you get around this problem? Is there a way to just disable the FPCM and let the primary pump run at 12 volts all the time without the CEL being tripped? I can't disable it in the tune
    Gray Ghost- The abomination. 2007 Chevrolet Silverado CCSB. 98mm turbo, nitrous, 428LSX, Rossler 80E with a brake. Finally finished. 23 psi, no numbers, Slow as hell.
    PBM G8- Aluminum 364, twin Precision 67/66 turbos, 6L90 trans swap, CTS-V/Vaporworx fuel system, slowly making progress.
    Dads 2011 CTS-V- Stock bottom end, stock heads, LS9 cam, pullies, ported blower, ported TB, D3 goodies, and lots of nitrous.
    618/618 motor
    906/862 spray
    Caterpillar 50 Forklift- Duramax swap
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Unplug the FPCM, fix the codes, and power the pumps straight off the battery with a relay for ignition on power only.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Aug 2010
    Roswell, N.M.
    1,956
    Even if I disable the FPCM, there's no way to turn off/get rid of the codes.
    618/618 motor
    906/862 spray
    Mar 2008
    St. Louis, MO
    4,859
    If you unplug it completely, sure there is. The module itself can't throw a code, and you'll just have loss of communication, which you can turn off.
    Aug 2010
    Roswell, N.M.
    1,956
    Hmm, I wonder if I can simply pull the FPCM fuse..... Then run the existing wires that power the fuel pump off the FPCM to the terminal stub on the fuse box.
    Then that would leave the eliminate the need for the actual rail pressure sensor and all that other crap.
    618/618 motor
    906/862 spray
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    Quote Originally Posted by IDRIVEAG8GT View Post
    how did it go?
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by ProTools4 View Post
    how did it go?
    I'm actually still working on it now.
    618/618 motor
    906/862 spray
    Advanced Tuner vette_c6's Avatar
    Jun 2008
    Kuwait
    390
    keep us update after you finish ,,
    specialize in: V8 Tuning (Kuwait)
    Abdullah Al-najdi
    00965 99369929
    www.youtube.com/alnajdi83
    Tuners ! Quit Raping your PE TABLE !
    instagram : alnajdi83
    best number in 1/8 mile 4.54 ( My Driving + My Tune ) !
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by vette_c6 View Post
    Well, I'm just trying to figure how to power the relay and keep everything under the hood civil. Motor is totally out right now as we lifted a head and blew a gasket at 22psi. :O
    So needless to say, there is a mess of wires strung everywhere to sort through lol.
    618/618 motor
    906/862 spray
    Aug 2010
    Detroit, MI
    930
    Pins 85 and 86 power the relay.
    Aug 2010
    Roswell, N.M.
    1,956
    Quote Originally Posted by smokeshow View Post
    The actual fuel pump?
    618/618 motor
    906/862 spray
    Aug 2010
    Detroit, MI
    930
    I was being sarcastic haha. But yeah pretty much all relays use the same pins for the coil trigger.
    Aug 2010
    Roswell, N.M.
    1,956
    G'damn! that's useful to know.
    618/618 motor
    906/862 spray
    Mar 2006
    sunny So Cal
    292
    here is my controbution
    it is yet to go on the dyno
    But it works on the rack
    hope this helps someone
    test car
    2010 Silverado 2-wheel drive 5.3
    LSX376 w/ cogged 2300 Maggy
    walbro 400 pump
    AN send return fuel lines w/ rising rate adj return reg
    process to delete FPCM with return fuel system
    Unpluged the FPCM
    *under the bed of the trucks above the spare
    *passenger side rear seat under the quarter window on the 5thgen camaro
    Large Pins 47 & 16 with around 10 gauge wire supply ground and power to the pump
    ground is Pink ...WTF~!
    Depin the connector and repin for new weather pack relay
    Pin 13 Dark Green / white stripe is the trigger form the PCM key hot.
    in HPT turn off P0230 and U0109
    go make power!
    NotoriouSS TAD
    Aug 2010
    Roswell, N.M.
    1,956
    test car
    walbro 400 pump
    Unpluged the FPCM
    go make power!
    :nohomohug:
    But it's under the spare?! thats where that goofy bunch of wires went lol.
    618/618 motor
    906/862 spray
    Aug 2010
    Roswell, N.M.
    1,956
    And also, could you simply not cut the hot wire trigger for th FPCM then wire it to the power for the fuel pump. Wouldn't that eliminate the need for the relay? And then the FPCM fuse would simply act as the fuse for the fuel pump? Or am I thinking wrong here.
    618/618 motor
    906/862 spray
    Aug 2010
    Detroit, MI
    930
    Isn't your truck a 2007? Pretty sure 2007s in certain applications didn't have an FPCM, so it has to have the manual relay trigger. Pin 50 on the X1 ECM connector, DK GRN/WHT wire. That is what I am currently using until I can get my FPCM operational. Mines an 08 and still has the trigger, so you should be fine.
    Aug 2010
    Roswell, N.M.
    1,956
    Nah mine is an 07 but it does have the FPCM voltage modulator
    618/618 motor
    906/862 spray
    Jan 2007
    30
    If I remember correctly if you unplug the FPCM you have to jumper the GMLAN wires to keep the communications bus in tact. May cause other system issues if you leave the FPCM disconnected.
    When you are done with the mods, disconnect the battery and measure pins 6 & 14 on the aldl. If they are 120 ohms and not 60 ohms you need to fix your can bus. (FPCM has passthrough communications)
    John
    I'm running a dual pump setup on an 08. I'm using the racetronix harness and relays to power the pumps. Also bought a transistor from ADM performance to use low voltage power from the ECM to trigger a low voltage relay which triggers the racetronix relay. Remove the fuse for the FPCM and tune on the communication codes. Works great. I've got a wiring diagram around here some where of how I wired everything. ADM has used the transistor in the past to defeat the FPCM on the 2010+ camaros.
