Any one have the map settings for a LE5 2 bar conversion? The factory linear is 18.583.. Is that a 1 and 1/4 bar map? never done this before other than on the LNF. Anyhelp would be appreciated.
HP-Unlimited Tuning and Custom Fabrication
Houston area performance parts dealer
MD800 Mustang Dyno 713-560-3889 Taylor
2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
Thank you very much sir! I have been looking around to try and find a 2 bar set up but wasnt sure if I had it done right.
Edit: Im not doubting you on these settings, but do you mind explaining how you come to those figures? Is there a formula to use when scaling maps? Or is that just the way it is and you have to copy them over from a different setup?
