Very new to tuning here, working on a stock 07 Cobalt 2.2 in a buggy. I need info on how to take the lag time out of the accelerator pedal. I have been changing the brake torque limits. Am I in the right tables? While running scanner with pedal floored scanner is showing 55% throttle btl set at 2.000 (stock is 1.372). I maxed out the brake torque limit table to 6.042 pedal was very responsive and would go to 88% (which is the 100% for the 4.39 volts I think?). Problem is ecm keeps throwing a p0606 code shutting down the pedal. While still running in limp mode when I delete the DTCs pedal comes back.
There may be a simple solution to the problem, as I said in the beginning I am very new to this.
Thanks for any help
